bent layshaft
martinr
anybody ever had a bent layshaft :?
Ruudboy
wow, that whole engine must be ready for the bin...
I just got a MB layshaft, it looks really nice!
netweasel
Check the layshaft needle bearing race in the endplate. If it is worn at all it can cause the layshaft to spin just slightly out-of-true and then the layshaft will then be off balance causing your rear wheel to wobble.
Either way, when you replace your layshaft, you should replace the layshaft needle bearing race in the endplate.
    Users browsing this forum: Baidu [Spider] and 16 guests
