Page 1 of 2
can anyone help........
Posted: Sun Mar 28, 2010 4:46 pm
by leehuggy72
Tried everything and getting no nearer to sorting my carb problem out..
i know i've mentioned this before but have come to a brick wall
I've got two keihin pwk 28/30mm carbs i've been playing with... both oko copies... one of them came off a running scooter
rubber mounted..
scooter idles fine 42 pilot.
soon as i take the choke off it eventually dies
now i'm thinking of something like an air leak as it dies if i use the throttle..
whats the best way to check........wd40????
sorry about bringing this up again any help would be great........
Re: can anyone help........
Posted: Sun Mar 28, 2010 5:43 pm
by Andy Pickering
Have you thought about maybe going the Dellorto route Lee..? there doesnt seem to be a lot of experience around with these carbs, well not up to now..just had a look around the forum and seen a few set ups for 28/30mm dells so maybe give up the fight and trade up for a dell Lee...gets you on the road buddy, hope someone comes along with some advice mate..
Posted: Sun Mar 28, 2010 5:59 pm
by leehuggy72
It has to be something really simple... the carbs have been cleaned ultrasonically and with compressed air...
i feel i have to look at every option as its money spent on jets manifold carbs etc..
i feel it may be time to put the lot on ebay and do what you said LAM46
Posted: Sun Mar 28, 2010 6:31 pm
by corrado
I'd get it set up on a dyno, it's cheaper than a new carb.
What needle are you using?
Posted: Sun Mar 28, 2010 7:04 pm
by leehuggy72
bgm 28 needle jjh equivalent
42 pilot
120 main
float set 22mm
Posted: Sun Mar 28, 2010 11:10 pm
by corrado
Does it run OK with the choke on?
Does adjusting the clip position on the needle make any difference.
Posted: Sun Mar 28, 2010 11:12 pm
by sean brady scooters
corrado wrote:Does it run OK with the choke on?
he said that martin....
Posted: Sun Mar 28, 2010 11:17 pm
by corrado
sean brady scooters wrote:corrado wrote:Does it run OK with the choke on?
I took it as it idles OK with choke, but doesn't actually say that he runs it with choke.
Posted: Sun Mar 28, 2010 11:39 pm
by coaster
My money is still on it being a blockage of some sort. Rather than an airline, use a wd40 or similar spray with a long nozzle and squirt it down all the orifices and check that something comes out of the other end.
It would need to be a fairly monumental airleak for it to die just reving it on the stand.
Posted: Mon Mar 29, 2010 11:12 am
by dapper
Lee, did you follow my reply on this carb problem on your previous post? Can you see light through the tiny hole in the carb next to the main jet (pilot hole)? Did you melt off the float stop in the bottom of the float bowl? I've got the 24mm OKO carb on mine and had to do the above. PM me if you need any more advice.
