Page 1 of 3
Tv2 revamp
Posted: Fri Mar 26, 2010 11:09 pm
by Fux
My tv2 started to look a bit shabby round the edges so I decided to make it a little more shabby.
Rattle can 2 pak.....
Custom pipe..
I`ll take some more pics once I start re-building....
Re: Tv2 revamp
Posted: Sat Mar 27, 2010 4:22 pm
by LI150
Ur Tv looked gorgeous intrested to see what this will look like when your done
Re: Tv2 revamp
Posted: Sat Mar 27, 2010 6:45 pm
by Fux
I came a cropper on some diesel last year and wrecked the paintwork :cry:
I havn`t realy got money for a full profesional paint job and had some niggles like a leaky petrol tank, poor speedo.
So I have thrown another grand at it and I won`t have to worry too much about the paintwork.
Its been ridden all over scandinavia and I just fancied having a scoot that pokes its nose out a little more.
More pics...
reinforced the strut for a sidestand
Can`t afford new footboard strips, and may use skateboard tape?
Re: Tv2 revamp
Posted: Sat Mar 27, 2010 7:06 pm
by riley
look forward to seeing the finished product
like the sound of using grip tape
Re: Tv2 revamp
Posted: Sat Mar 27, 2010 8:11 pm
by Richjak
go for it mate its usually the "i dont have a lot of dough to spend on it" type projects that give birth to the best inovative ideas.
Please keep us all posted i am loving what i am seeing keep that spirit of 63 mod s**t this is what i am talking about.
Re: Tv2 revamp
Posted: Sat Mar 27, 2010 8:53 pm
by Fux
Ironicly, I have sold a couple of tv2`s that ended up as Gran Sport "resto`s" .
I am actualy realy pleased with the flames, not bad for a first timer.
I am going back in the garage to see if the leggies still fit :?
Re: Tv2 revamp
Posted: Sun Mar 28, 2010 11:02 am
by Fux
Quite a few hours in the garage yesterday.
I hellicoiled the engine case and swapped a few dodgy crankcase studs.
Tapped the holes in the maghouse so that I have a full set of screws again.
Drilled and tapped a fin for the heat sensor.
Fit the cowlings.
Pipe got som bandage, if you plan on doing this use some gloves as I learnt the hard way (ouch) Fingers are full of fibre now :(
Fit the pipe (looks MEAN!)
Back out in the garage...
I am, like many others I know a complete idiot when it comes to wireing and Byron off thse boards is a genius! He is making me an easy to follow diagram including battery and dials and its all going to be connected in the toolbox. He is a top fella, and will save me loads of time. I think I used about two weeks of swearing last time I build the scoot :oops:
Re: Tv2 revamp
Posted: Sun Mar 28, 2010 5:03 pm
by Fux
At the mo I have been messing about fitting the leggies. The holes where they fit the frame are now wider after the weld job so I`ll have to have a look at that later.
To get them on I had to take off the fork and chrome ring so they are just on loose at the mo so I can get under them for the wireing and new cables.
In order to order new cables I have to determin the hight of my bars something I also have to fix.
Firstly, to get these to go clear of the leggies I have to angle them quite high. That in turn pushes the bars way out front.
The problem here is that i am a shortarse and its going to be a tw@7 to ride.
The angle I think it will ride best in is this but I`ll need more hight.
There are a few ways to achive some hight.
1. Higher risers
2. Shim the bottom of the risers I have
3. Use a riser shim like this.. adapters.
Looking at the measurments I need a total of 2.5 inch.
I`m not sure what the best method would be?
Re: Tv2 revamp
Posted: Sun Mar 28, 2010 5:14 pm
by Fux
Iv`e seen these on ebay
I could machine them down half an inch and fit a stud in the bottom.
Or even these... And do the same but i would proberbly have to cut the leading edge of them so that dont stick out at the front.
Hmm........
Re: Tv2 revamp
Posted: Sun Mar 28, 2010 6:04 pm
by Fux
Ok, sorted.
Just need to measure cable and hose length for Chiggy.
