urgently needed - who sells 35mm tmx throttle/choke cables?
Posted: Mon Mar 22, 2010 8:38 pm
by soullad
Swapping over from dellorto phbh to 35mm TMX so need a new throttle cable and choke cable asap. Its for an S2 if that makes a difference?
Ian
Re: urgently needed - who sells 35mm tmx throttle/choke cabl
Posted: Mon Mar 22, 2010 8:40 pm
by sean brady scooters
try knowledge on here..... :D
Posted: Mon Mar 22, 2010 9:12 pm
by soulsurfer
Are you paying attention Ian? Knowledge IS your man :lol:
Posted: Mon Mar 22, 2010 9:24 pm
by peter357bikes
Corrado
Posted: Mon Mar 22, 2010 10:46 pm
by soullad
Cheers Guys.
Posted: Tue Mar 23, 2010 12:07 am
by Knowledge
I have had trouble logging onto this forum today, so sorry if I appeared inattentive.
I can make you a choke cable for a TMX35 for £5 in postage. This is one without an in-line adjuster. In fact, I can make them for most carbs, to order. Black or grey. Mine are designed to work without an elbow, but again, I can accommodate this if you wish.
I'm afraid all the adjustable ones have gone now. I will continue to look for a supplier of adjusters so I can make these a regular item in my catalogue.
