Page 1 of 2
Expansion pipe end can rivets
Posted: Thu Feb 05, 2009 9:06 pm
by Ihateyoubutler
Just re-packed an exhaust end can and wondered if there are any special rivets required to put it back together? Or if there is any other way of doing it to make future re-packs any easier?
Thanks.
Re: Expansion pipe end can rivets
Posted: Thu Feb 05, 2009 9:12 pm
by shocky
Ihateyoubutler wrote:Just re-packed an exhaust end can and wondered if there are any special rivets required to put it back together? Or if there is any other way of doing it to make future re-packs any easier?
Thanks.
what pipe is it i tapped mine but this was a pm tail can
Posted: Thu Feb 05, 2009 9:15 pm
by Ihateyoubutler
Alright Shocky, it's a (sorry!) scorpion.
Posted: Thu Feb 05, 2009 10:49 pm
by Knowledge
When I got a re-pack kit from Cam LAm, it came with some heavy duty rivets. They were like normal pop rivets, but you couldn't see the knob on the top of the rivet. They have stayed in place.
They look like this:
You can buy them at Screwfix
Posted: Thu Feb 05, 2009 10:58 pm
by sean brady scooters
Posted: Thu Feb 05, 2009 11:42 pm
by Dazza
For that perfect far east resto look!
Posted: Fri Feb 06, 2009 6:06 am
by Diablo
I use heavey duty stainless rivits from a place called mattesons in Coventry. They need either a pnumatic riviter or one of those big scissor type rivitors to fit them though.
Posted: Fri Feb 06, 2009 10:42 am
by Ihateyoubutler
Thanks for the help.
Posted: Fri Feb 06, 2009 12:21 pm
by RinB
Diablo wrote:I use heavey duty stainless rivits from a place called mattesons in Coventry. They need either a pnumatic riviter or one of those big scissor type rivitors to fit them though.
I use the same but too be honest this is my life failing on Lamies.
Ask everybody in our club they use crash helmet not because its the Law but also
because of my flying tailpipes cant seen to keep them on.
But saying that Ive got a Vespa Sterling end can modified to fit on reflections ,and this has stayed on the longest of any.
By the way Ive used PM, NK, Scorpions, JL's all types of exhausts.
A tip I have now been told is to heat up the rivot before fitting.
This apparently lets you put more pressure on the crimp as the tail stretches slightly before you get the snapping off
Smiffy
Posted: Fri Feb 06, 2009 7:05 pm
by Knowledge
I remember Graham Best telling me that he once has a scooter in at kegra. The entire chain case was secured with wood screws and rawplugs.
