Page 1 of 3
Compression height on KH750 piston
Posted: Thu Feb 05, 2009 7:38 pm
by davidblythe
Can anyone tell me the crown and dome height on this piston
Re: Compression height on KH750 piston
Posted: Thu Feb 05, 2009 7:55 pm
by sean brady scooters
32mm compression height i think
Posted: Thu Feb 05, 2009 8:18 pm
by davidblythe
cant be right, a 116mm rod is used with them possibly 22mm
Posted: Thu Feb 05, 2009 9:53 pm
by drunkmunkey6969
davidblythe wrote:cant be right, a 116mm rod is used with them possibly 22mm
Posted: Thu Feb 05, 2009 9:57 pm
by drunkmunkey6969
If a Lambo is 39mm on a 107 rod...then a KH must be approx 30mm on a 116 rod?
Sean wont be far off....? 22mm is a bit whacky though?
I believe (from my incredibly bad memory) that they are actually 31mm to be honest...but will stand corrected if anyone says different?
Posted: Thu Feb 05, 2009 10:04 pm
by J1MS
Compression height 32mm is correct. Top Of the class Sean
Posted: Thu Feb 05, 2009 10:08 pm
by J1MS
davidblythe wrote:Can anyone tell me the crown and dome height on this piston
I would have to measure one of mine, as I cant remember profile height.
Posted: Thu Feb 05, 2009 10:11 pm
by davidblythe
crown height measured from top of gudgeon pin to edge of piston crown
prefer this definition as the piston catolgue i have use this (unfortunately doesnt include H2 piston)
Posted: Thu Feb 05, 2009 10:12 pm
by davidblythe
drunkmunkey6969 wrote:If a Lambo is 39mm on a 107 rod...then a KH must be approx 30mm on a 116 rod?
Dan are you measuring from middle of the gudgeon pin at 39mm for Lammy piston ?
Posted: Thu Feb 05, 2009 10:13 pm
by davidblythe
J1MS wrote:Compression height 32mm is correct. Top Of the class Sean
so 24mm in new money
