Page 1 of 2
old school "taffspeed style" ts1 yam set up
Posted: Sat Mar 20, 2010 12:50 pm
by mickdale
did the old ts1 200 kits with conversion run a yanaha dt175 piston and gp crank with tv175 conrod?
if so are the old tv175 conrods ok perforamce wise for this kit?
cheers
mick
Re: old school "taffspeed style" ts1 yam set up
Posted: Sat Mar 20, 2010 12:56 pm
by soosh
Mine is an IT175 with an RD400 rod
Posted: Sat Mar 20, 2010 1:03 pm
by wack 63
Can't remember if mine in the 80's ran a 60 stroke TV rod with the IT175 piston .Used it on the race track for a year no probs.
Posted: Sat Mar 20, 2010 5:03 pm
by shocky
mine ran ok on a tv rod only replaced it when i had a 240 conversion done and went for a 71mm piston with 18mm big ended 116mm rod on a 60mm stroke crank
Posted: Sat Mar 20, 2010 8:46 pm
by J1MS
I think AF still keeps the Yamaha 175 IT piston in stock.
Posted: Sat Mar 20, 2010 9:34 pm
by GP Kevo
Mine was IT175 piston on 115 mm conrod (Yamaha RD400 like above I think). Very smooth revving TS1.
Posted: Sun Mar 21, 2010 5:36 pm
by gaz_powell
i`m starting to get the patrs together to do one - got genuine it175 piston, crank done with rd400 115mm long rod in 58mm stroke webs
barrel next - needs re plating or may steel liner it - yet to decide
Posted: Sun Mar 21, 2010 6:30 pm
by YAMLAM
im also running IT175 piston on 115mm (RD 400 Rod) GP crank TS1 200
Used a tv rodded Gp crank with a DT175 piston in a cast barrell ( piston windows welded in ) for the last 10 years. not sure if you can use the DT piston in a TS1( ring pegs might be in wrong position, i know on my cast barrell one of them had been repegged.(by Taffspeed)
Posted: Sun Mar 21, 2010 7:26 pm
by mickdale
hello jake
got the dt175 piston (new) and a gp crank with tv175 rod (i think steve said taffspeed did the conversion years ago with quality big end bearing)
also got a brand new 60mm mec crank
just picked up a ts1 200cc barrel (needs replating)
havent got a clue what set up to choose
60mm crank with ts1 piston
tv175 rod with dt/it 175 piston
dt/it 175 piston with a different rod 58mm stroke crank
was thinking of using miku i tm24 carb on the set up like you as a tourer
cheers
mick
Posted: Tue Mar 23, 2010 8:19 pm
by Rosi-C9
Mine is a Wiseco IT 175 Piston (right) running on a BGM Crank (60/ 115 RD 400 rod).
I guess it´s also possible to use an Blaster piston which is used for an RB20 (left) or DT 175 (middle) but you have to displace the rings pins.
