Headlight problem
Posted: Sat Mar 20, 2010 11:56 am
by D10
My Li headlight isn't bright enough to ride at night, even with a halogen bulb fitted. Strangely, it brightens a lot when I apply the brakes (front and rear brake light switches fitted). Thought it might be a bad earth so now have 3 good earths - also changed the ignition, checked the switch & replaced the bulb holder and checked all connections. Still no change - can anyone help please??!!
Re: Headlight problem
Posted: Sat Mar 20, 2010 1:09 pm
by wack 63
Have you checked the rear bulb is correct way round? Thick filament to top for the brake.Are you on 6v or 12?
Posted: Sat Mar 20, 2010 1:17 pm
by firekdp
If you are on standard 6V check your rear lights earth as well as the above.
Posted: Sat Mar 20, 2010 1:35 pm
by D10
I'm on 12v - it's an MB set up with BGM stator. The rear bulb is the correct way round and the earth is good. I have no idea what it could be. Very occasionally the lights brighten on their own (without braking, suggesting earth problem) but that hasn't happended for a couple of months.
Posted: Sat Mar 20, 2010 1:55 pm
by wack 63
Might be worth checking the the stator lighting coils and wire first,then substitute another regulator and check the loom terminal and earth on the reg.
