60mm crank with monza/ts1 for torque?
Posted: Fri Mar 19, 2010 10:15 pm
by mickdale
starting building an engine with a mec 60mm crank and after torque rather than high revs/peaky hp
was thinking along the lines of a manza or ts1
should i leave the kits as standard or is there anything i could do to increase ridability?
(havent decided on pipe)
cheers
mick
or is classic rapido/tm24/ancilotti the way to go
Re: 60mm crank with monza/ts1 for torque?
Posted: Fri Mar 19, 2010 10:23 pm
by sean brady scooters
you could do far worse than the ts1 with 1mm off bottom of barrel as per MB,s touring tune..........
Posted: Sat Mar 20, 2010 6:28 am
by mickdale
can you still take 1mm from the base of the cylinder with a 60mm crank?
cheers
mick
