Front fork spring question
Posted: Thu Mar 18, 2010 6:53 pm
by desi
Sorry if this appears a silly question - I take it the fork rod passes through the springstop/top hat? If so how do the the later large washer types stay in place?
Re: Front fork spring question
Posted: Thu Mar 18, 2010 7:03 pm
by soulsurfer
There's a stop welded in the fork leg, the washer type pushes up against this
Posted: Thu Mar 18, 2010 7:04 pm
by dapper
If you look up through the fork leg, there are welded in stops wiv holes through them for the top bit of the fork rod to pass through. You should be able to see traces of the welds from the outside.
Posted: Thu Mar 18, 2010 7:08 pm
by desi
Thanks for replies
