Carb set-up Casa 210
Posted: Thu Mar 18, 2010 5:04 pm
by TS1-200
Anyone had any experiences with the Casa 210, I am fitting one for a mate, any ideas on jetting for a delly 30mm PHBH , Sterling expansion pipe
Re: Carb set-up Casa 210
Posted: Thu Mar 18, 2010 11:16 pm
by rog60
Done about 600 miles on mine but using 28mm dellorto PHBH 120 main, 50 pilot, 40 slide, X12 needle (2nd clip down), AV266 atomiser, remote foam filter and KBA 42mm clubman.................any use?? 55 mpg.
Posted: Fri Mar 19, 2010 9:57 pm
by TS1-200
rog60 wrote:Done about 600 miles on mine but using 28mm dellorto PHBH 120 main, 50 pilot, 40 slide, X12 needle (2nd clip down), AV266 atomiser, remote foam filter and KBA 42mm clubman.................any use?? 55 mpg.
How does it go on that set up,
Posted: Fri Mar 19, 2010 11:40 pm
by rog60
That's a hard one to answer as I cruise arond 50 - 55mph and don't thrash it. I bought it as 'improved lower revs pulling power' was stated and this is what it gives. I run on SX150 gears and 19 x 47 sprockets. the engine is fairly quick on acceleration and just keeps pulling to end of revs or limit of carb set-up, much better than an iron cylinder on hills especially. I am quite happy with it but, with hindsight, perhaps my money should have gone on a more proven design. The engine does need to be dynoed tho, and that is the next step.
Posted: Thu May 06, 2010 9:52 pm
by rog60
I've also set up a PHBH 26 large body with AV264,102/5 main, 52 idle 40 slide and X7 needle 2clips down same setb up as 28 mm carb
