Page 1 of 12
Aprillia RS125 smallie engine
Posted: Thu Mar 18, 2010 12:42 am
by Wayne Miller
Heres a pic of my smallie casings with Aprillia RS125 cylinder attached.
The casings have been machined for the cylinder to fit, and machined to fit a 54mm full circle crank
Sill got to remove lots of the ally welding as I had loads of weld put on as I wasnt sure what Id need, this is only the second smallie engine that I ve built so Im learning as I go along
Next job is to fit the crank to check that the measurements for the packer height were correct
Lots more to do so I'll stick a few pics up as and when
Re: Aprillia RS125 smallie engine
Posted: Thu Mar 18, 2010 1:03 am
by drunkmunkey6969
Now thats what i call a project...................get on! ;o))
Posted: Thu Mar 18, 2010 9:36 pm
by oldbiker
That`s the way to do it. that will be one mother of an engine when it`s all finished.
any idea of what exhaust you are going to fit??
Posted: Thu Mar 18, 2010 11:13 pm
by Wayne Miller
tzr.steve wrote:That`s the way to do it. that will be one mother of an engine when it`s all finished.
Ive only got one option and thats to get one custom made.
Ive already spoken to a number of people about it and just weighing up my options at the moment
Posted: Thu Mar 18, 2010 11:17 pm
by sean brady scooters
Wayne Miller wrote:tzr.steve wrote:That`s the way to do it. that will be one mother of an engine when it`s all finished.
that sounds expensive......
Posted: Thu Mar 18, 2010 11:37 pm
by Knowledge
Interesting.
I have an Aprillia barrel and cagiva Mito barrel in the workshop awaiting such a project. Lots of things are holding me back at the moment, but I have at least looked at the problems with such conversions.
I thought the Cagiva barrel to be slightly easier to fit, as it was simpler to extract the water from the bottom of the barrel. However, the challenges are many, especially once you start making serious power. What are you doing for a clutch?
I am going to follow this with interest. I love it.
Posted: Thu Mar 18, 2010 11:52 pm
exhaust wise, consider using the std aprillia one,just adapt it to fit and give it a longer reflective cone to suit your four speed box........also a slightly longer down pipe....
just an idea ,and if you could do this your self it could save you £100s
one off pipes can be very expensive,would not be suprised if you,ve had quotes of £500 plus.
Posted: Thu Mar 18, 2010 11:58 pm
by Wayne Miller
Ive had quotes between £500 and £800 up to now
Clutch wise im using this :
Posted: Fri Mar 19, 2010 12:01 am
by Wayne Miller
PS bearing pressure plate is the wrong way round in the pic
my fault being a f*ckwit
Posted: Fri Mar 19, 2010 12:13 am
by Wayne Miller
Ive just checked on fleabay and it looks like I could pick up a standard pipe for the better side of £100.
With my budget being hindered slightly reasontly this could get me back on track and on the road in just over a month me thinks.
I'll ask a few more questions later about how best to alter it when I get round to a pipe Sean
