About to seal a tank..
Posted: Sun Mar 14, 2010 10:12 pm
by Dazza
I'm just about to seal a new tank, if I pour the whole can of sealant in the tank and swill it around for 10 minutes as per instructions - should I pour off any excess or just leave the tank on it's side so that any excess sets away from the filler or outlet boss?
Any other tips for sealing?
Re: About to seal a tank..
Posted: Mon Mar 15, 2010 12:10 am
by camel
it goes off pretty dam quick...i kept rotating the tank to keep an even spread of the stuff...as i said it goes off quick so you wont be doing it for long
Posted: Mon Mar 15, 2010 12:16 am
by soulsurfer
Use as the instructions say regarding quantity and rotate for the recommended time or a bit more. I set the tank to rest and cure so that any excess can run out the fuel tap hole.
Posted: Mon Mar 15, 2010 12:21 am
by J1MS
^^^What he said^^^
Posted: Mon Mar 15, 2010 7:58 am
by wlightning
Why bother sealing a tank just take your time and keep washing it out, then fit a good quality filter. Any way you dont go fast enough to worrie about your petrol tank :bouncing: :bouncyeng:
Posted: Mon Mar 15, 2010 8:32 pm
by fattspeed
camel wrote:it goes off pretty dam quick...i kept rotating the tank to keep an even spread of the stuff...as i said it goes off quick so you wont be doing it for long
what stuff are you using in the tank do you have a link ????/
Posted: Mon Mar 15, 2010 10:29 pm
by Dazza
wlightning wrote:Any way you dont go fast enough to worrie about your petrol tank :bouncing: :bouncyeng:
b@11@x!
Carl, It's a far eastern origin tank and I don't want to worry about it springing a leak so I'm just sealing for peace of mind
Posted: Mon Mar 15, 2010 11:32 pm
by wlightning
Daz i think most guys do seal there petrol tanks now days so dont blame you sealing it look forward to see you soon
