battery problem
Posted: Fri Mar 12, 2010 5:06 pm
by trg258
could someone explain why after a 50 mile ride my 6 volt battery discharged to 2 volts its a four pole stator on a series two no brake light as standard i have green to double green brown to brown blue to grey red to purple on regulator the fuse is ok red wire to + on battery - to earth everthing else on the bike works
Re: battery problem
Posted: Fri Mar 12, 2010 5:22 pm
by firekdp
Faulty rectifier?
Re: battery problem
Posted: Fri Mar 12, 2010 5:35 pm
by trg258
firekdp wrote:Faulty rectifier?
are you sure its only 50 years old is the wiring correct T
Re: battery problem
Posted: Fri Mar 12, 2010 6:30 pm
by DMC
one of your grey hairs aint fell out and you,ve tried connecting it to the red have you? And is 258 correct after the last rebore?
Re: battery problem
Posted: Fri Mar 12, 2010 6:40 pm
by firekdp
No, I'm not sure because it's not in front of me to check it. :D If the reg/rec is the correct one and each wire is plugged into the socket with it's corresponding colour then it can only be correct, but if you want to check then, the browns and the greens only use the reg/rec box as a junction. The red only connects to the fuse, grey goes to the other side of the fuse and on to the regulator coil, blue goes to one side of the selenium plate rectifier with purple going to the other side of the rectifier and other side of the regulator.
Are you sure that it isn't simply a faulty battery as at 2v it probably is now.
Re: battery problem
Posted: Fri Mar 12, 2010 8:51 pm
by trg258
yes it is faulty now its the second battery is there any way of checking the regulator i have a multi meter but upto now have only used it for voltage checks and continuity checks
Re: battery problem
Posted: Fri Mar 12, 2010 8:55 pm
by trg258
DMC wrote:one of your grey hairs aint fell out and you,ve tried connecting it to the red have you? And is 258 correct after the last rebore?
if one of my grey hairs had fell out i would haved noticed i dont have many left tuby
Re: battery problem
Posted: Sat Mar 13, 2010 6:50 pm
by firekdp
The charging rates given for your model are approx. 0.6A at 3000rpm and 1A at 5000rpm, but for this a good battery should be fitted. If it is overcharging your electrolyte levels will drop quickly and when seriously overcharging will smell awful.
