JL3 on a Series 2
Posted: Fri Mar 12, 2010 11:02 am
by Bofs
Just wondering will a JL3 fit a Series 2? Don`t mind trimming the runner board
Re: JL3 on a Series 2
Posted: Fri Mar 12, 2010 2:53 pm
by eibargum
Yes it will, ive got a Franspeed jobby on mine [same pipe] and it fits fine, though i did use a fettled MB rear bracket, i dont rate the JL ones at all.
Posted: Fri Mar 12, 2010 4:08 pm
by Bofs
Cheers, what`s up with the JL rear brackets?
Posted: Fri Mar 12, 2010 9:41 pm
by ratty
JL now do a jl3 to fit ser 2s,the new style brackets aint bad,scooter loopy john has re-made the rear mount,ive got one its a good solid bit of kit.....big bad john is his e bay name does some trick kit for lammys.
Posted: Sat Mar 13, 2010 10:28 pm
by Fux
John`s e-bay name is Big Bad Barry, b.t.w....
Posted: Sun Mar 14, 2010 4:01 pm
by ratty
oops sorry...
Posted: Mon May 10, 2010 7:17 am
by mark
anyone got a link to the mb brackets please?
Posted: Tue May 11, 2010 8:25 am
by Bofs
Just an update on this. It was a major pain in the hole fitting the JL3 to my S2 due to the routing of the downpipe which comes up under the left hand runner board.I had to panel beat the board nearly inside out to get clearance but since my scooter is a bit ratty I didn`t mind so much. The end can bracket also had to be fettled quite a bit to get clearance on the side panel. It`s on though and looks sweet :D
If you`re thinking of doing the same then save your pennies and buy the JL designed for Series 2`s, CLW4 I think. :roll:
