Page 1 of 3
Rear Wheel Oil Seal????
Posted: Thu Mar 11, 2010 10:48 pm
by rog60
Any other suggestions on how to SUCCESSFULLY fit the oilseal to the rear wheel bearing with bearing in place..........
After removing the old seal I warm and grease the lip of the new seal and bearing surface and using a large socket tap the seal in gently. I use Rolf seals but always end up with the seal not going in straight, spring from back jumping off or inner lip turning inside out.........
Anyone with a better/simpler suggestion......................pretty please
Re: Rear Wheel Oil Seal????
Posted: Thu Mar 11, 2010 10:49 pm
by DJB
Use a fly press.
Posted: Thu Mar 11, 2010 10:50 pm
by joespeed
try pressing the seal in not shocking it with the hammer!
Posted: Thu Mar 11, 2010 10:54 pm
by rog60
joespeed wrote:try pressing the seal in not shocking it with the hammer!
Can't do that, too tight.
Posted: Thu Mar 11, 2010 10:56 pm
by DJB
rog60 wrote:joespeed wrote:try pressing the seal in not shocking it with the hammer!
Then try a different make of seal.
Posted: Thu Mar 11, 2010 10:57 pm
by rog60
DJB wrote:Use a fly press.
Don't know anyone with one suitable
Posted: Thu Mar 11, 2010 11:01 pm
by DJB
rog60 wrote:DJB wrote:Use a fly press.
Most workshops should have one "Motorbikes, scooters, cars, engineers.
Posted: Thu Mar 11, 2010 11:03 pm
by rog60
DJB wrote:rog60 wrote:DJB wrote:Use a fly press.
Thanks. Ask around tomorrow.
Posted: Fri Mar 12, 2010 5:37 pm
by mickyb
get a peice of plastic, the type used on vacuum packaging, just long enough to go round axle, hold it in a cylinder and push through seal, oil the seal and plastic. put plastic tube over axle and slide seal into place, press home, remove plastic and hey presto, job done.
Posted: Fri Mar 12, 2010 6:35 pm
by monkey boy
Lincs Lambretta sell a tool that they have developed especialy for this problem.
Give em a try
CHEERS AL
