smiths speedo
Posted: Tue Mar 09, 2010 9:33 pm
by C*NTSPEED
can this be used on a scoot rs disc hub?
http://www.royalspares.com/smiths-speed ... -2357.html
Re: smiths speedo
Posted: Tue Mar 09, 2010 9:38 pm
by soulsurfer
I suspect depth will be your problem, they're much deeper than a genuine Smiths speedo and that's tight on a SX headset.
Re: smiths speedo
Posted: Tue Mar 09, 2010 10:11 pm
by gaz_powell
yes you can but - as soulsurfer said they are deeper - i`ve just finished one - had to make the ali ring on the headset top deeper and get the angle right and modify the headset bottom clamp to route the cable - had to faff about with the cable abit but you can use a standard indian gp/sx type
sorry no photo`s top is at painters and clamp at powder coaters
all in all in looks okay for the cost - jet headset was laying around in garage, top modified inc ali ring £40.00, speedo £20 + cable and a bit of garage time + paint - will end up been no more £90.00
Re: smiths speedo
Posted: Tue Mar 09, 2010 10:14 pm
by C*NTSPEED
its not going in a bwetta headset but some custom bars wi ape hangers
Re: smiths speedo
Posted: Wed Mar 10, 2010 8:41 pm
by GlosRob
Really like the idea of doing my sx 150 as an S type how hard are original Smith Speedo's to get ? I guess they need to be modified and calibrated ?
Re: smiths speedo
Posted: Wed Mar 10, 2010 10:05 pm
by camel
it has to be re-calebrated to suit a10inch wheel...then a modified lambretta cable can be used to suit your scootrs disc....i basically glued some shims onto the the speedo end of the lambretta cable to allow the cable to drive it....at least thats what i did on my s type replica
Re: smiths speedo
Posted: Thu Mar 11, 2010 9:52 am
by GlosRob
Where do I source parts from to complete the conversion ?
