i want to stick a k&n filter on my phbh but forgot to measure it ,does anyone know?
Re: air filter size?
Posted: Sat Mar 06, 2010 11:07 pm
by cezeta
you want to concider the breath sweet one.
Posted: Sat Mar 06, 2010 11:17 pm
by mark
i know what one i can use i really need size of clamping area
Posted: Sun Mar 07, 2010 4:30 pm
by GP Kevo
Is there a larger Breath Sweet filter? One with a slighly larger rubber bellows mounting face to the carb? Like one to fit the Mikuni TMX-35 whose bellmouth diameter is 62 mm?
Posted: Mon Mar 08, 2010 10:31 pm
by rog60
I'm using the standard rubber hose (22mm size) and a short piece of plastic waste pipe over the threaded inlet on a 28PHBH to give a better seal (can't remember the size of pipe tho)
Posted: Mon Apr 19, 2010 11:22 pm
by skidmark
GP Kevo wrote:Is there a larger Breath Sweet filter? One with a slighly larger rubber bellows mounting face to the carb? Like one to fit the Mikuni TMX-35 whose bellmouth diameter is 62 mm?
Scooter Centre Koln do a 60mm one that fits the TMX 35 I have one fitted to my Rapido 250 and seems to work well.
Posted: Tue Apr 20, 2010 9:25 am
by GP Kevo
Thanks for that, skidmark. I have the CamLam breath sweet filter which I have now stretched over the carb bellmouth but I'll check out the SCK one as it will be much less of a stretch.
Here's a vid of my bike with the filter mounted. I now have a jubilee clip securing the rubber bellows to the carb.
