Page 1 of 2
loose exhaust nuts
Posted: Sat Mar 06, 2010 9:12 pm
by roadrunnerian
i have a gp 200 which seems to loosen its brass exhaust nuts every time i go out. i have tried
flat washer, flat washer and spring washer and now its double nuts. any one had this problem?
Re: loose exhaust nuts
Posted: Sat Mar 06, 2010 9:15 pm
by DJB
roadrunnerian wrote:i have a gp 200 which seems to loosen its brass exhaust nuts every time i go out. i have tried
David Blythe is your man for this. He sell nutts that can be wired. Excellent bit of kit.
Posted: Sat Mar 06, 2010 9:17 pm
by RinB
Suggest changing studs as well
Posted: Sat Mar 06, 2010 9:19 pm
by DJB
RinB wrote:Suggest changing studs as well
Oh, dont forget to use stud lock
Posted: Sat Mar 06, 2010 9:29 pm
by Bufficus
Depending on what exhaust you are using? Double nut using high tensile if you can find them. The brass jobbies on some exhaust barrel combinations never work.
Posted: Sat Mar 06, 2010 9:41 pm
by byron
DJB wrote:David Blythe is your man for this. He sell nutts that can be wired. Excellent bit of kit.
yeah, I'd go with that. or make up some tab washers, been threads on here about that
Posted: Sat Mar 06, 2010 11:23 pm
by rog60
byron wrote:DJB wrote:David Blythe is your man for this. He sell nutts that can be wired. Excellent bit of kit.
Use the tab washers that lock the upper chain tensioner studs/bolts...........worked for me.
Posted: Sun Mar 07, 2010 10:22 am
by Dazza
rog60 wrote:byron wrote:Use the tab washers that lock the upper chain tensioner studs/bolts...........worked for me.
same here
Posted: Sun Mar 07, 2010 4:50 pm
by shocky
Posted: Mon Mar 08, 2010 9:24 pm
by roadrunnerian
thanks all for your replies tab washers it is then
