Bellmouth suggestions
Posted: Sat Mar 06, 2010 8:54 pm
by sydduckett
Have a 30m delly on my rb20 which is running unfiltered. Problem is its chucking loads of fuel out, so wanted to put a bellmouth on so the sprayback was farther away from the side. i dont run with pannels but ideally would want one that fits with pannels on, there vented so it can be quite close.
Ta
sef
Re: Bellmouth suggestions
Posted: Sat Mar 06, 2010 9:58 pm
by Knowledge
The Dell'orto bellmouth is plastic, so you can cut it to whatever length you like. As standard, I think it is about 30-35mm long.
Posted: Sun Mar 07, 2010 1:12 am
by Diablo
They do a nice ally one as well with a wide mesh. About £20 from euro carb It will change your fueling charateristics abit. Usually cleans up the low to mid range but does curtail over rev.
Eurocarb number 01189431180 very helpful and next day delivery.
Posted: Sun Mar 07, 2010 1:17 am
by sydduckett
Diablo wrote:They do a nice ally one as well with a wide mesh. About £20 from euro carb It will change your fueling charateristics abit. Usually cleans up the low to mid range but does curtail over rev.
Can i tell them the size of the carb and they then send the correct one out?
Posted: Sun Mar 07, 2010 12:15 pm
by Diablo
Yes but as Martin says you just need to know if yours will screw on or push fit and clamp with a hose clip.
Posted: Mon Mar 08, 2010 12:42 am
by sydduckett
Diablo wrote:Yes but as Martin says you just need to know if yours will screw on or push fit and clamp with a hose clip.
Looks as though there is a lip for a jubilee clip?
