JB five plate...
Posted: Sat Mar 06, 2010 8:48 pm
by sydduckett
Have the JB 5 plate set up. They also sell a top hat that goes with it which turns it into a 6 plate. Does anyone have this set up and if so whats the diff between the 5-6 versions. Im thinking of upgrading but want to know the pros and cons. It comes with mb springs and its popeye time when pulling in on a reg basis around town so hoping the 6 is a bit easier...
Any feedback...
ta
sef
Re: JB five plate...
Posted: Sat Mar 06, 2010 9:56 pm
by Knowledge
I don't know the difference (perhaps thinner smooth plates), but JB will be at Wicksteed tomorrow so you can ask him. The weather looks fine, sunny, if a bit chilly. so wrap-up warm.
Posted: Sat Mar 06, 2010 11:29 pm
by Toddy
sydduckett wrote:Have the JB 5 plate set up. They also sell a top hat that goes with it which turns it into a 6 plate. Does anyone have this set up and if so whats the diff between the 5-6 versions. Im thinking of upgrading but want to know the pros and cons. It comes with mb springs and its popeye time when pulling in on a reg basis around town so hoping the 6 is a bit easier...
Any feedback...
ta
sef
You say you JB 5 plate is hard to pull in i have three of these on different engines and they are heaven compared to my old 4 plate with center springs
Posted: Sun Mar 07, 2010 1:13 am
by sydduckett
Toddy wrote:sydduckett wrote:Have the JB 5 plate set up. They also sell a top hat that goes with it which turns it into a 6 plate. Does anyone have this set up and if so whats the diff between the 5-6 versions. Im thinking of upgrading but want to know the pros and cons. It comes with mb springs and its popeye time when pulling in on a reg basis around town so hoping the 6 is a bit easier...
Any feedback...
ta
sef
i have a feeling i left the centre spring in as well...
might this have somthing to do with it?
Posted: Sun Mar 07, 2010 1:15 am
by sydduckett
Knowledge wrote:I don't know the difference (perhaps thinner smooth plates), but JB will be at Wicksteed tomorrow so you can ask him. The weather looks fine, sunny, if a bit chilly. so wrap-up warm.
mart, not going tomorrow, twinny blew it out. If you see john and remeber ask him about the advantges. If not no worries.
Cheers
sef
Posted: Mon Mar 08, 2010 7:23 am
by Toddy
sydduckett wrote:Toddy wrote:sydduckett wrote:Have the JB 5 plate set up. They also sell a top hat that goes with it which turns it into a 6 plate. Does anyone have this set up and if so whats the diff between the 5-6 versions. Im thinking of upgrading but want to know the pros and cons. It comes with mb springs and its popeye time when pulling in on a reg basis around town so hoping the 6 is a bit easier...
Any feedback...
ta
sef
Sef
Dont think you will need the center spring with JB's 5 plate mate .
Posted: Mon Mar 08, 2010 6:28 pm
by sydduckett
From memory i think it came with 4 mb springs and i kept the cenre spring in as well. Presumably this would make it stiff to pull in, would removing the centre spring make it softer and not compromise the effectivness of it?
ta
sef
Posted: Tue Mar 09, 2010 7:14 am
by Toddy
sydduckett wrote:From memory i think it came with 4 mb springs and i kept the cenre spring in as well. Presumably this would make it stiff to pull in, would removing the centre spring make it softer and not compromise the effectivness of it?
ta
sef
Sef
Think the center spreing is more for the 4 plate set up to give you a little extra , with the 5 plate you dont need it so it wont comprimise the effectivness mate , my jb 5 plates give me a two finger light lever and no slippage yet
What engine do you have it fitted in ??
Posted: Tue Mar 09, 2010 8:02 am
by timdig
no centre spring in my jb 5plate. 5 sprint meetings and 4k of rally milage. no problem pulling the lever. have you tryed a new cable or checked the routing? tim
Posted: Wed Mar 10, 2010 10:56 pm
by sydduckett
Toddy wrote:sydduckett wrote:From memory i think it came with 4 mb springs and i kept the cenre spring in as well. Presumably this would make it stiff to pull in, would removing the centre spring make it softer and not compromise the effectivness of it?
ta
sef
Sef
Have got a RB20 which is about 20 brake. will whip out the centre spring and see how i get on.
Ta
