Why has this happened.....
Posted: Sat Mar 06, 2010 7:13 pm
by celt
Re: Why has this happened.....
Posted: Sat Mar 06, 2010 7:23 pm
by Bufficus
Yes, I've had similar. A poor quality remade thimble wore through, but didn't get as far as removing the nipple.
Posted: Sat Mar 06, 2010 9:14 pm
by jason frost
Bufficus wrote:Yes, I've had similar. A poor quality remade thimble wore through, but didn't get as far as removing the nipple.
Crap parts never had this happen with Innocenti bits.
Posted: Sat Mar 06, 2010 9:18 pm
by Bufficus
jason frost wrote:Bufficus wrote:Yes, I've had similar. A poor quality remade thimble wore through, but didn't get as far as removing the nipple.
Indeed Jason, a quick rummage through my old engine trays turned up an Innocenti item that has been fine ever since.
Posted: Sat Mar 06, 2010 10:14 pm
by celt
It was an Innocenti nipple (I hope), came out of a SX150, and it was a snug fit.
It is the second time this has happened. First time I found the thimble had worn through and you can see what has happened the second time.
I just don't know why this is happening
:baddevil:
Any suggestions other than bad fitting thimble
Posted: Sat Mar 06, 2010 10:28 pm
by jason frost
celt wrote:It was an Innocenti nipple (I hope), came out of a SX150, and it was a snug fit.
:baddevil:
Looking at it the centre it could be pattern, this could be it, had some that had worn abit but never like this.
Posted: Sun Mar 07, 2010 8:38 pm
by wack 63
Dare say the pressure plate is warped causing it to revolve out of true thus making the nipple run off centre. I had this trouble on a TS1 with Indian pressure plates and strong springs that warped two plates before I sussed the problem. So converted a one piece Innocenti Li plate removing the nipple, to GP spec and have had no trouble since. There was a reason Innocenti fitted the earlier clutches with the cluster centre pin perhaps this is why.Also looks to have rubbed on the casing as well.
Posted: Sun Mar 07, 2010 9:00 pm
by sean brady scooters
this sort of thing can also be caused by not having any free play in clutch cable adjustment............
in other words,if your clutch cable is over tight,then the arm will always be putting pressure on the nipple,...which can cause lack of lube and friction build up........
Posted: Mon Mar 08, 2010 1:15 am
by celt
Thanks for the comments
No wonder Dan had trouble with the clutch when I brought it up for a dyno last Autumn
