tm24 carb inlet manufacture
Posted: Fri Mar 05, 2010 6:09 pm
my mikuni tm24 carb doesnt stay on the mb inlet manifold well
the inlet rubber onlt has a "lip" on one side - the one that sits in the groove machined in the carb inlet body.
the other side doesnt hold securely onto the straight inlet manifold
i tighten it up but once the engine is at running temperature the rubber is no longer tight, so i tighten it a bit more - but iot wont stay tight
this is the second engine ive had this trouble on and ive run out of patience and sick of "ive never heard of that before" (not from rayspeed)
i would like to use a flanged rubber inlet rubber to go onto my carb. i need to get hold of either an alloy flanged inlet manifold that attaches to the rubber or an ali flange on its own - i want to ally weld the flange onto my mb inlet manifold so i can have a secure long term solution for peace of mind
does anyone know of an ally inlet manifold (24mm) that fits on a motorbike i can modify or a place where i can buy one from
any advice/point in the rught direction greatly appreciated
cheers
mick
cheers
mick
