kick 'non' start
Posted: Sun Feb 28, 2010 5:27 pm
by minotaur
.... had a bit of a scraping noise in chaincase which disappears when clutch is pulled. tried to kick yesterday and kick start only turns engine every 4th kick, thought clutch might be slightly engaged so un hooked cable and still the same, this is a new build so could it be plunger? looks like another job for next w'end :(
Re: kick 'non' start
Posted: Sun Feb 28, 2010 6:07 pm
by soullad
minotaur wrote:.... had a bit of a scraping noise in chaincase which disappears when clutch is pulled. tried to kick yesterday and kick start only turns engine every 4th kick, thought clutch might be slightly engaged so un hooked cable and still the same, this is a new build so could it be plunger? looks like another job for next w'end :(
just sounds like the inner kickstart shoulder rubbing on yer top clutch steel...........Just either grind a little off the shaft or fit a thinner top plate.
Posted: Sun Feb 28, 2010 8:40 pm
by minotaur
hope it's just that , kicked over fine for a couple of weeks, thanks
