Hallite Gasket
Posted: Fri Feb 26, 2010 9:31 pm
by thackers
Asking for a mate looking for a quick answer, is the Halite gasket crucial or just a added bonus. Re-build going on now for tommorow. Help please ;)
Re: Hallite Gasket
Posted: Fri Feb 26, 2010 9:42 pm
by sean brady scooters
its there and used for a very good reason.............
its not an added bonus.......... :lol:
Re: Hallite Gasket
Posted: Fri Feb 26, 2010 9:46 pm
by thackers
Thanks Sean, i'll let him know, his words were if it's 75% safe he would take a chance, from your answer i'd guess it's not worth the risk
Re: Hallite Gasket
Posted: Sat Feb 27, 2010 2:31 pm
by Terrible Taff
thackers wrote:Asking for a mate looking for a quick answer, is the Halite gasket crucial or just a added bonus. Re-build going on now for tommorow. Help please ;)
The Halite gasket is there to seal the drive plate to the bearing this stopping a short circuit of crankcase pressure & that of sucking gearbox oil into the engine.
Do not use sealed driveside bearings as this does not allow oil to lubricate the one side of the drive side double lipped seal!
I have found them fitted in many an engine that came through our workshop.
Also fit the seal with the spring inwards to the crankshaft! If you have the indian alloy seal retaining plate these can distort when tightening the 4 screws, use a steel one.
Ian Frankland
Taffspeed
Re: Hallite Gasket
Posted: Sat Feb 27, 2010 10:09 pm
by thackers
Thanks for the replys i believe he stopped the rebuild and tracked back to the missed gasket
