Jockey's Boxenstop fastner kit
Posted: Fri Feb 26, 2010 11:33 am
by dansuper
Now, I bet that got your attention...
Recently purchased their fastener kit (see link below) and it doesn't come with any instructions as to what goes where.
Does anyone one have a comprehensive fastener 'map' that shows what goes where? I think Casa may supply one with their kits but my local dealer was out of stock.
Cheers,
Dan
https://www.scooter-center.com/scoweb/p ... egory2=CAT
Re: Jockey's Boxenstop fastner kit
Posted: Fri Feb 26, 2010 1:36 pm
by dapper
LAMBRETTA fixings list
1.Horn Casting
M5 x 10mm Pan Head Slotted Screw (2 Required)
M6 x 18mm Allen Head Screw + 2x6mm Conical Washers (2 Sets Required)
M5 x 20mm Countersunk Oval Slotted Screw + Finishing Washer (2 Sets Required)
M5 x 16mm Hex Head Bolt + 5mm Large Diameter Conical Washer (2 Sets Required)
M4 x 10mm Countersunk Oval Head Slotted Screw (Oval is optional, just looks better) (2 Required)
2.Front Mudguard
M5 x 25mm Countersunk Flat Top Slotted Screw + 5mm Nut, 5mm Conical Washer (2 Sets Required)
M5 x 20mm Countersunk Oval Slotted Screw + Finishing Washer, 5mm Nut, 5mm Conical Washer (2 Sets Required)
3.Floor Set inc. Bridge Plate
M4 x 10mm Pan Head Screw + 4mm Speed Nut, and
M4 x 20mm Pan Head Screw + 4mm Nut, 4mm Large Diameter Washer
M4 x 10mm Pan Head Screw + 4mm Speed Nut (2 Sets required)
(In lieu of speed nuts, you can use plain nuts and washers)
M4 x 20mm Countersunk Oval Slotted Screw + 4mm Nuts, 4mm Washers (4 Sets Required)
M4 x 25mm Countersunk Oval Slotted Screw + 4 mm Nuts, 4mm Large Diameter Washers (2 Sets Required)
M4 x 10 Countersunk Oval Slotted Screw = Finishing Nut (2 Sets Required)
14 x 5mm Nuts
14 x 5mm Conical Washers
10 x 5mm Speed Nuts
M5 x 25 Countersunk Oval Slotted Screw + 5mm Nut, 5mm Conical Washer
4.Dual Seat
M8 x 25mm Hex Head Bolt + 8mm Nut, 8mm Washer (8 Sets Required)
4 x 8mm Flat Metal Washer
Large Diameter 8mm Plastic Washer. (4 Required)
5.Frame ‘L’ Bracket
M7 x 20mm Hex Head Bolt + 7mm Nut, 7mm Conical Washer (2 Sets Required)
6.Engine Cowlings
M5 x 10mm Slotted Hex Head Bolt + 5mm Lock Washer (7 Required)
M8 x 14mm Hex Head Bolt + 8mm Conical Washer (1 Required)
7.Headset
M5 x 40mm Countersunk Oval Slotted Screw + 5mm Countersunk Internal Lock Washer (2 Sets Required)
M6 x 10mm Countersunk Oval Slotted Screw (2 Required)
M3 x 20mm Countersunk Oval Machine Screw (Philips Head) (4 Required)
M3 x 22mm Countersunk Flat Slotted Screw (2 Required)
Posted: Fri Feb 26, 2010 3:51 pm
by Bilko
Nice one Dapper. I've been looking for that list. Now copied and pasted
Posted: Sat Feb 27, 2010 12:34 am
by dansuper
Thanks Dapper! Brilliant. :D
