Setting up a Battery for my EGT. Help please.......
Posted: Thu Feb 25, 2010 9:10 pm
I am running an EGT at the mo, powered via a Vespa type regulator with a DC output on my TS1 240. The problem is, is that the power dips down too low at tick over and the Egt switches off.
What i have decided to do is to run a battery in my glove box and switch it on and off, manually, with a switch when needed. But here is the question: Can i use a rechargable the battery by just connect the positive and earth from the Regulator and top the juice up that way and connect the feed to the EGT to the Positive and earth on the battery? Will the battery just act as a buffer for the EGT? Will it charging when there is too much power for the EGT to use and also keeping it working at tick over when it normally cuts out? Is it that simple, or have i underestimated a complex wiring solution.
