STRONG stand spring recommendations??
Posted: Wed Feb 24, 2010 2:53 pm
by lammysilver
After a stronger better stand spring to replace my original knackerd one.
Any suggestions
Re: STRONG stand spring recommendations??
Posted: Wed Feb 24, 2010 3:35 pm
by Knowledge
Why a STRONG spring? Are there some weak ones out there (I wouldn't be surprised)?
I ask because most issues with droopy stand have little to do with the spring, but a lot to do with wear in the stand components. The stands get bent, the U clamps wear badly and rarely get greased, but the worst problem is usually on the frame cross-member that the stand is fixed to. This is usually bad on Italian machines, as "stand-abuse" can result in the fixing bolts for the U clamps pulling through the steel of the cross-member. The usual solution is a thick rectangular washer on the inside of the cross member and some new bolts. Serveta did this as standard on many frames. Innocenti were too mean to do it as standard.
OK, so your frame and stand might be in perfect nick, but others might be reading this and this might help them rectify similar problems.
Posted: Wed Feb 24, 2010 6:01 pm
by vince
100 % with you on this one Martin , I could not even imagine trying to fir a stronger spring if all is as it should be on the stand components they work fine.
Posted: Wed Feb 24, 2010 6:13 pm
by DJB
There are two different length springs, you may have the long one. Just a thought.
Posted: Wed Feb 24, 2010 6:27 pm
by lammysilver
sorted, my pal had a spare, mine was just old and needed replacing whilst doing a rebuild thats all.
Cheers for the info though, ive sorted the strengthening blocks for the rebuild also.
Thanks again
Posted: Thu Feb 25, 2010 11:32 pm
by shocky
DJB wrote:There are two different length springs, you may have the long one. Just a thought.
or 3,4 or 5 from sc@@t @s :shock:
