Page 1 of 2
power problem
Posted: Tue Feb 23, 2010 7:13 pm
by roadrunnerian
i have noticed with my stage 4 gp200 which has had 3mm cut off sometimes when you open it up it goes great but when i was overtaking some cars i had to shut off then open up it won't go give it 20 seconds and it goes. could the cut off the piston be the trouble any advice
would be gratefull thanks
Re: power problem
Posted: Tue Feb 23, 2010 7:20 pm
by sean brady scooters
your trouble is probably down to carb set up.....did you have it dyno,d after the tuning mods..?
Re: power problem
Posted: Tue Feb 23, 2010 8:42 pm
by Dazza
Fuel supply flow rate?
Re: power problem
Posted: Wed Feb 24, 2010 7:22 am
by roadrunnerian
thanks for the quick replies no i have not had it dyno,d because the person who built the engine said it was all set up right.how much do you charge per hour? i live near chorley its not far
Re: power problem
Posted: Wed Feb 24, 2010 10:17 am
by lee b
hello ian!!!
Re: power problem
Posted: Wed Feb 24, 2010 10:41 am
by Stampede
would be the blowback, i think. perhaps go for a LTH manifold to sort it!
Longer inlet timing (shorter piston
) doesn´t make this problem better....
Which carb do you use? A big one, bigger than 25mm?
Re: power problem
Posted: Wed Feb 24, 2010 8:32 pm
by roadrunnerian
i have a 28mm carb on the scoot m8
Re: power problem
Posted: Wed Feb 24, 2010 8:50 pm
your carb settings,irrispective of what carb or size it is will need setting up for the new stage 4 tune.....
your tuner should have advised you in that respect........
typically you may find the need for a smaller pilot jet,and maybe diffuser and needle changes....etc
perhaps post up your carb /engine details and then maybe we can give you some pointers
Re: power problem
Posted: Wed Feb 24, 2010 10:42 pm
by soosh
What pipe you running?
Re: power problem
Posted: Thu Feb 25, 2010 8:29 am
by chris2470
Is it a PWK type carb by any chance ??
