is this the ideal gauge, egt, cht and rev counter with alarm
Posted: Sun Feb 21, 2010 7:30 pm
by cezeta
seems to have included everything into one gauge with programable alarms. looks good to me...can anyomnre think of any downsides before i buy one?
http://www.occpowersports.com/eshopprod ... METER_.htm
Re: is this the ideal gauge, egt, cht and rev counter with alarm
Posted: Sun Feb 21, 2010 7:36 pm
by micky1
looks good to me,where are the extra sensors listed? would be good to have all the bases covered, could even do a bit of a group buy???
Posted: Sun Feb 21, 2010 7:42 pm
by cezeta
here is a uk supplier, i have bought from them before. maybe a phone call is needed
http://www.digital-speedos.co.uk/
Posted: Sun Feb 21, 2010 8:02 pm
by shocky
does it do EGT AND CHT
Posted: Sun Feb 21, 2010 8:08 pm
by cezeta
shocky wrote:does it do EGT AND CHT
Highly visible, backlit digital display shows RPM and dual temperatures
Large digital rpm readout and REV bar-graph make it easy to read rpm at high speeds; REV indicator is programmable to 10000, 15000 or 20000 rpm
Dual temp meters have programmable high-temp warning lights; 32-482°F range (0-250°C)
Records max rpm and temp
Also features volt meter, time, programmable shift light and optional air/fuel ratio meter
Includes water temperature sensor; EGT sensors, oil temperature sensors and cylinder head temperature sensors available separately
Measures 85.7mm W x 30.5mm H x 19mm D
it looks like it, all the sensors are thermistors so there should be no reason why not?
Posted: Sun Feb 21, 2010 8:33 pm
by trev t
just got one of these mb developments,, very good
Posted: Sun Feb 21, 2010 8:34 pm
by mark
Does it work with single stroke engines
Posted: Sun Feb 21, 2010 9:34 pm
by soulsurfer
Looking at the instructions it seems it does a/f ratio but not EGT. No sensor listed and the temp guage only reads up to 250degC. Nice guage all the same.
Posted: Sun Feb 21, 2010 10:13 pm
by cezeta
i think you are right
however they do this one
Posted: Sun Feb 21, 2010 10:14 pm
by cezeta
