Re: Bearing options
Posted: Sun Feb 21, 2010 4:34 pm
by shocky
i was gonna say i get mine from simply bearings but noticed some of those on amazon are dispatched from there . i set up an account with SB and get 10% off, there also really helpfull if you phone and dispatch the same day or next morning if the item is in stock
Re: Bearing options
Posted: Sun Feb 21, 2010 10:38 pm
by hydra
Eden, you don't know me from Adam, but I have in stock everyone of the above Bearings and can match, if not beat all the prices you have quoted from Amazon. All my Bearings are SKF except the Clutch/crownwheel needle which are Torrington. If you require any please let me know.
Re: Bearing options
Posted: Mon Feb 22, 2010 7:32 pm
by dirtyhandslopez
Not open too big of a can of worms, but which country of origin are the SKF's? I am not seeing any SKF's made in Europe any more. My bearing stockist don't know where their bearings will come from anymore FAG or SKF, it doesn't matter.
A suppose the question is just because they have a brand name on them, are all countries that manufacture for that name held to exactly the same standards?
Re: Bearing options
Posted: Tue Mar 02, 2010 12:24 pm
by Piatti
hydra wrote:Eden, you don't know me from Adam, but I have in stock everyone of the above Bearings and can match, if not beat all the prices you have quoted from Amazon. All my Bearings are SKF except the Clutch/crownwheel needle which are Torrington. If you require any please let me know.
Hi Hydra,
Can you please supply prices for the following bearings please, plus delivery (uk)
1. Flywheel/Magneto side - ref: NU205 ECP – size 25x52x15
2. Drive side – ref: 6305 C3 2RS – size 25x62x17
3. Final drive (rear hub) – ref: specialist lambretta bearing ?
4. Gear box end plate - ref: 6004
5. End plate layshaft (needle) size 20x24x10
6. Small end needle roller (fits in Con Rod) - size 16x20x20
7. Gear cluster (needle), slots in casing - size 16x22x12
8. Rear sprocket needle roller (2 Required) - size 24x28x10
cheers
Piatti
Re: Bearing options
Posted: Sat Mar 06, 2010 11:40 pm
by fullmetaldany
Hi the torrington needle bearings are better than SKF a client from me drove the f**kers for 12 years!!!!
Most off the SKF bearings are now from potugal or romennia or low cost production
if you spend so mutch money on an engine then you take the best bearings you get for your money
for me thats: INA: needel bearings ore Torrington
: NSK (japan racing bearings top quality)
oilseals: viton!! ( cost a litlle bit more but the are heat resitant 100% !!!! )
and this is the wright set up :-)
good luck
take care
Fullmetaldany
Re: Bearing options
Posted: Tue Aug 02, 2011 9:43 pm
by the-brickie
A friend brought a cheap set of bearings off ebay, marked 'SKF' but also 'made in India' I advised not to use them but he did, got 3/4 of the way home from Mersea and he broke down, electrical probs, on investigation he found the mag side bearing collar had broke in half causing the flywheel to oscilate.
Also looked up Bearingboys and they are a bit cheaper too.
This lot look even cheaper!
http://www.bearingshopuk.co.uk/popular- ... -6-8-c.asp
Whats the code for a rear hub bearing?
