Page 1 of 2
SLJ Rear mounting bracket
Posted: Fri Feb 19, 2010 6:12 pm
by bazman
Hi have fitted one of these but unsure if it's supposed to have a lot of play in rear muffler? See attached video , what do you guys think? Cheers Baz.
http://www.youtube.com/watch?v=uL8jeGnEy4I
Re: SLJ Rear mounting bracket
Posted: Fri Feb 19, 2010 7:01 pm
by lockman69
Bazman, I have just fitted mine, (JL3) I have a bit of play also, maybe not as much as you, there is a fair bit of play on the rubber cotton reel.
Posted: Fri Feb 19, 2010 8:12 pm
by bazman
Cheers , yeah meant to say there's a lot play in the heavy duty rubber cotton reel!
Posted: Sat Feb 20, 2010 9:56 pm
by hydra
MBD Devtour bracket on a JL3 End
Posted: Sat Feb 20, 2010 10:09 pm
by Bufficus
Similar to mine. But I use a Devtour bracket and end can on my TS1/JL4
Posted: Sat Feb 20, 2010 10:18 pm
by Bufficus
Is the SLJ bracket is the same as the brackets supplied with JL/Franspeed pipes? If so, move the bracket in a clockwise direction onto the next set of studs and the bobbin should line up with the hole in the end can support.
The Franspeed race pipe on my RB is fitted like this and works a treat. No need for an additional tie bar. (picture to follow if required)
If the SLJ bracket is different, apologies for butting in.
Posted: Sat Feb 20, 2010 11:05 pm
by bazman
Hi , no it's not the same unfortunately, similar to franspeed , did try all the mounting arrangements but no joy. Will have another look 2moz, like the idea of the mb devtour bracket though
Does the devtour tailcan fit the jl's ok?
Posted: Sat Feb 20, 2010 11:12 pm
by Bufficus
Bit tight, but goes in. Better looking and sounding than the JL IMO.
Posted: Sat Feb 20, 2010 11:32 pm
by hydra
another view of MBD Devtour bracket on JL3
Posted: Sun Feb 21, 2010 2:41 pm
by bazman
That looks a bit more substanial
Do you have too get extended chaincase studs for the mounting bracket?
Also do you know how much and can they be purchased seperately?
Thanks Baz.
