fresco exhaust
Posted: Wed Feb 17, 2010 8:19 pm
by roadrunnerian
hi has any one had problems fitting these exhausts i tried fitting one to my gp200 and found the crankcase brkt was over half inch out and you had to pack it out as well so it does not touch the side panel
Re: fresco exhaust
Posted: Wed Feb 17, 2010 9:25 pm
by Bilko
Do you mean an 80's one?
I have an OTK 80's Fresco I was trying to fit my LI at the weekend and the crankcase bracket was out.
Re: fresco exhaust
Posted: Thu Feb 18, 2010 7:55 am
by roadrunnerian
Hi Bilko yes i have the same problem as you and same exhaust i remade the brkt to fit adding another captive nut and drilling another hole then slotting the two holes.
Re: fresco exhaust
Posted: Thu Feb 18, 2010 10:41 am
by lofty
if i remember rightly the OTT frescos were cut-and-shut regular ones and always needed some kind of packing at the crankcase bracket as the modification means they dont sit in the same position as the UKS ones..
Re: fresco exhaust
Posted: Thu Feb 18, 2010 11:01 am
by Bilko
I've put the PM on and will keep the Fresco back for the cutdown.
I've got problems stacked up to the f@@king roof, so this will have to wait.
Re: fresco exhaust
Posted: Thu Feb 18, 2010 8:27 pm
by roadrunnerian
i think i have sorted it by using extended nuts on the crankcase 8mm studs and fastening the brkt with
bolts going into the extended nuts. if all fails i have a scorpion i can fit.
