sealing joints on a JL3 tips, please?
Posted: Tue Feb 16, 2010 7:04 pm
by goffy
any advice on sealing the joints on a JL3 to stop any blowing, what do you guys use? cheers!
Re: sealing joints on a JL3 tips, please?
Posted: Tue Feb 16, 2010 7:08 pm
by shocky
bathroom silicone sealant
Posted: Tue Feb 16, 2010 7:15 pm
by goffy
thanks shocky,
so do you put the sealant around the outer part of the 2 joints, or put some sealant on so it sits inside when the 2 joints are put together, if you know what i mean?
Posted: Wed Feb 17, 2010 1:10 am
by Chris CSPE
So it sits inside, clean the joint with brake/clutch cleaner first .
Posted: Fri Feb 19, 2010 11:20 am
by Eibar
We have always used a length of mountain bike inner tube, perfect fit and doesn;t burn. simply rolls on and off - TOP TIP
Posted: Fri Feb 19, 2010 12:58 pm
by soullad
Eibar wrote:We have always used a length of mountain bike inner tube, perfect fit and doesn;t burn. simply rolls on and off - TOP TIP
Any pics? I assume you mean the tailcan joint .........what about the exhaust slip joint?
Posted: Tue Mar 02, 2010 1:21 pm
by Eibar
Yeah tailcan joint simply rolls, always done it, been no probs at all, 3"long
