R1 rear shock
Posted: Tue Feb 16, 2010 12:24 pm
hey all . is there a certain year of the yam r1 that the rear shock will fit to a lambretta, or will all fit?? its a toss up between the new bgm or a r1??
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Use the double nut methodKnowledge wrote:The R1 shock does not fit SI or SII frames very well and you must take care when securing the nuts at the top and bottom. Too tight, and the shock might break.
DJB wrote:Use the double nut methodKnowledge wrote:The R1 shock does not fit SI or SII frames very well and you must take care when securing the nuts at the top and bottom. Too tight, and the shock might break.
teamsequipe wrote:DJB wrote:Use the double nut methodKnowledge wrote:The R1 shock does not fit SI or SII frames very well and you must take care when securing the nuts at the top and bottom. Too tight, and the shock might break.![]()
And by using two thin nuts, locking them together , this can be achieved.sean brady scooters wrote:whilst the nuts need to be tight obviosly,they should not tighten up against the shocker bushes and so restrict the slight amount of movement that they require under suspension movement....
I would rather use 2 nuts for peace of mind,chiggy03 wrote:Why not use nyloc half nuts?
