ts1 reeds question
Posted: Fri Feb 12, 2010 3:29 pm
by ridden not hidden
hello all i would like to fit some boysen 2 stage reeds in my ts1 but they only fit without the reed cages can i run it like that would it be okay or do i need to modify reedblock?
Re: ts1 reeds question
Posted: Fri Feb 12, 2010 4:02 pm
by Stampede
with a RD350 reedblock? No problems at all!
Posted: Fri Feb 12, 2010 4:09 pm
by drunkmunkey6969
Remove the stops, you dont need them with the Boyesen reeds.
Posted: Fri Feb 12, 2010 7:35 pm
drunkmunkey6969 wrote:Remove the stops, you dont need them with the Boyesen reeds.
when you say stops do you mean the metal strips they come with or the actual cages ?
Posted: Fri Feb 12, 2010 8:42 pm
by J1MS
Remove the bendy bits of metal and put the new reeds on, held in place with the two supplied metal strips using the original screws. If you use the the original bent bits of metal ( Stays or Stops) they will restrict the operation of the two stage reeds
Posted: Fri Feb 12, 2010 8:56 pm
thanks j1ms thats cleared that up
Posted: Sat Feb 13, 2010 10:03 am
by col@garageartwerks
i put the 2 stage reeds in my bike and phoned mb developements about whether to use the cages or not, they said it was a matter of preference and the reeds would perform the same with or without the cages...thought it was maybe safer to run with the cages because of the closeness of the reed block to the piston.. i've been running mine with the cages on a yamaha reedblock with a spacer for over a year now without any difference in performance..
