JL3...
Posted: Tue Feb 09, 2010 5:41 pm
by lockman69
As the title says, I have a JL3 ... but what’s the secret with the 2 extended bolts that support the end can?....if there not constantly coming loose and falling out there sheering off.....really starting to p##s me off now...anybody else had and solved this problem.
Re: JL3...
Posted: Tue Feb 09, 2010 6:18 pm
by carlos fandango
lockman69 wrote:As the title says, I have a JL3 ... but what’s the secret with the 2 extended bolts that support the end can?....if there not constantly coming loose and falling out there sheering off.....really starting to p##s me off now...anybody else had and solved this problem.
Well ive loctited some all thread in instead of the bolts and then a nyloc nut and washer
Re: JL3...
Posted: Tue Feb 09, 2010 6:19 pm
by mark
use a scooter loopy john clamp best you can get imho
Re: JL3...
Posted: Tue Feb 09, 2010 6:23 pm
by joee
mark wrote:use a scooter loopy john clamp best you can get imho
what he said ...
Re: JL3...
Posted: Tue Feb 09, 2010 8:46 pm
by lockman69
Thanks lads
Re: JL3...
Posted: Tue Feb 09, 2010 8:56 pm
by hydra
MB's rear support bracket for the Devtour fits the JL spot on and picks up 4 of the chaincase studs, although these have to be changed for longer ones.
Re: JL3...
Posted: Tue Feb 09, 2010 9:46 pm
by cezeta
mine fell apart in iow, i replaced the bolts with longer ones and assembled it with black heat proof gasket sealantm on the threads as well. solid as a rock now.
