Page 1 of 2
kickstart s/2
Posted: Sat Feb 06, 2010 7:00 pm
by marburys
got sil engine for s/2 what kick start do i use any help please
Re: kickstart s/2
Posted: Sat Feb 06, 2010 9:26 pm
by Jet200
Series 1/2 kickstart pedal so it clears the wider footboards ;)
Re: kickstart s/2
Posted: Sat Feb 06, 2010 9:53 pm
by Mel K
Jet200 wrote:Series 1/2 kickstart pedal so it clears the wider footboards ;)
Won't you also need a series 2 side casing? Or extend the bit that rests on the rubber stop?
Re: kickstart s/2
Posted: Sat Feb 06, 2010 10:01 pm
by Yanker
Yes: extended by approx 50mm to reach the rubber stop: easy weld job, but better done on an old lever/b4 choromin' ;)
Re: kickstart s/2
Posted: Sun Feb 07, 2010 12:08 am
by marburys
i got series 2 sidecasing with kickstart on. Can i just fit it on sil engine
Re: kickstart s/2
Posted: Sun Feb 07, 2010 1:38 am
by jimmac
marburys wrote:i got series 2 sidecasing with kickstart on. Can i just fit it on sil engine
The chaincase side will fit, but remember that the SIL endplate is a different design (has the kick start ramp as part of the endplate, rather than part of the chaincase side).
Also, the S2 doesn't have the strengthening webs around the kickstart shaft, so you might find it will crack if you're using a larger capacity motor.
Re: kickstart s/2
Posted: Sun Feb 07, 2010 10:23 am
by marburys
thanks for all your help take easy option and weld bit on kick start
Re: kickstart s/2
Posted: Sun Feb 07, 2010 10:29 am
by Ian Hepworth
Easy option is to extend the part on the kickstart so it reaches the bump stop.
Harder option (with risk of crankcase side breaking where kickstart shaft goes in) use S1/2 crankcase side.
Harder option with more reliability - use a Spanish crankcase side where they are beefed up round the kickstart area.
Re: kickstart s/2
Posted: Sun Feb 07, 2010 10:58 am
by marburys
cheers for your help
Re: kickstart s/2
Posted: Sun Feb 07, 2010 5:48 pm
by dirtyhandslopez
I have an odd casing here. A S3 casing without the extra enforcing ribs, looks like a S1/2 where the kickstart shaft is, but is definately S3 where the kickstarts bumb stop is. Anyone know what this is? Pre-pre-mod S3 perhaps?
