Re-corking clutch plates
Knowledge
OK, it might sound a bit mad, but someone asked me this question today and I could only assume that it must be possible. He has a rare scooter, but can't find any clutch plates for it.
Any takers?
Martin
bristolmod
I know this has been done way back in the 1950's - they used wine bottle corks and a razor blade.
Don't know how they bonded it though
Scootering since 1968.
bristolmod wrote:I know this has been done way back in the 1950's - they used wine bottle corks and a razor blade.
Some sort of epoxy would do or even a high stregth super glue. I recon if the wine cork was fed through a metal tube of the same diameter it would act as a guide for the cutting blade.
Getting the corks thin enough would be the main problem altough you could probably 'face' them of on a sheet of sandpaper afterwards. I hope its not some sort of lambretta 6 plate jobby :shock: You could end up with a trend braking 2 plate conversion :oops:
Knowledge
LOL Coaster.
I know you can buy cork in flat sheets, because it is supplied in this form for uses as gaskets. However, I think that this is a bit beyond the DIY environment of my workshop. We're not averse to paying a company to re-cork some worn-out clutch plates, if we can find someone who can do it.
Martin
tony
Main scooter: 90ss
I volunteer to supply the wine corks. Pls send al the full bottles to me and I'll have the corks by the end of the week... hic.. :lol:
bristolmod
"end of the week" ????
You need someone with a drink problem methinks.............. :D
tony
Main scooter: 90ss
It is a 20 plate clutch isnt it? 8-)
davidblythe
i can see a situation in the next 20 years when we may need to have this knowledge, i wonder what people do with very early motorbikes made in the first 30 years of the last century
who is going to make consumables for 70 year old machinery
can you still buy cork plates for models A's
Knowledge
Well I thought Tony had his tongue in his cheek, which must make drinking wine rather messy, but when I googled "clutch plate re-corking", I found this:
It is a photo of a clutch plate restored by a company called "Vintage Car Parts". They charge £1 per cork.
Martin
davidblythe
make wine drinking a bit cheaper if you can get a quid back for the cork :lol:
