Two Carbs
Posted: Thu Feb 04, 2010 4:53 pm
by Doom Patrol
Two Spanish 20mm carbs. There is a difference, as the eagle eyed among you will note. I don't know the technical term for it and what effect the longer spout has, but why is this? Would I be correct in assuming that one might be for a 150 and t'other for a 200?
Re: Two Carbs
Posted: Thu Feb 04, 2010 5:18 pm
by Innocenti-71
Just checked in the garage: left (like Dell´Orto) one is "early/mid" models, right one is Lince/Lynx.
Since my Lince is 200cc I don´t know if they used this version also on the 125/150cc.
Re: Two Carbs
Posted: Thu Feb 04, 2010 6:41 pm
by Doom Patrol
That's interesting. So the left hand one might just as well have been used on both 150's and 200's in which case. I'd assumed the later one might have been adapted to improve the flow of air and improve the mixture perhaps, looking rather similar to the Dell'orto 22mm carbs and possibly being only for the 200's.
Re: Two Carbs
Posted: Thu Feb 04, 2010 8:50 pm
by storkfoot
I have an 18mm Spanish that has the longer "trumpet" which, I presume, is designed to provide a longer inlet tract because of the tune of the engine :idea:
I also have a 20mm Spanish one like the one on the right in the photo. I don't know what it came off, but it's going to go on a Lynx 200 :D .
