Squish
Posted: Sat Jan 31, 2009 2:37 pm
by ArmandTanzarian
Hello all,
I've just got my barrel etc back from JB Tuning after some mild tuning. (mostly just just making sure everything matches and flows right)
I know how to measure squish using solder but what is the best way to adjust it? Is it better to add gasket width to the head or the base?
Re: Squish
Posted: Sat Jan 31, 2009 2:42 pm
by J1MS
Replacing just the head gasket with a different thickness will only alter squish clearance and compression where as the base gasket will also effect the port timings slightly.
Re: Squish
Posted: Sat Jan 31, 2009 2:49 pm
by ArmandTanzarian
Cheers.
Since JB has just spent his time and my money on matching them up I guess that the head is the one to adjust.
Re: Squish
Posted: Sat Jan 31, 2009 2:59 pm
by davidblythe
unless he knew the deck clearance beforehand the port timings are an approximation anyway
check these, then you will know where to adjust
Re: Squish
Posted: Sat Jan 31, 2009 3:13 pm
by ArmandTanzarian
He knew it was for a spanish casing which he said had a deck height 1mm more than an Italian one. (as do Indian ones apparently)
Re: Squish
Posted: Sat Jan 31, 2009 3:23 pm
by davidblythe
deck height is measured where the piston finishes at tdc in relation to the barrell 1mm can make a difference of 5 degs on the port timings
