Head Gasket fitting
chris2470
I have been told there is no need to run a head gasket on my standard 200. Therefore, this way you can pack the base by this amount to raise the timings and set the squish so there is no need to fit the top gasket.
Should I use some silicon on the top end or perhaps something else to get a good seal?
PS I know the inlet timing will shorten accordingly so will remove 1mm or so form the piston inlet side once calculated.
Best Regards
Chris
dapper
High temperature silicone or Blue Hylomar or Loctite ??? (look in Sticky's advanced engine build section and check what Loctite number MB uses), but don't use too much, just a thin bead so it doesn't get squished into your combustion chamber, and let it go off for a while before starting or even turning your engine by hand
