exhaust probs
Posted: Thu Jan 28, 2010 2:20 pm
by oggy
bought a copy DJ,The clamp does not seem that robust,any body know where i can get one from,no u clamps please.
Re: exhaust probs
Posted: Thu Jan 28, 2010 3:44 pm
by dapper
Try SLP (Scooterloopy John) I think he does a proper machined clamp for exhausts in different sizes.
Re: exhaust probs
Posted: Thu Jan 28, 2010 8:59 pm
by gaz_powell
agreed - definately get the SLJ type
Re: exhaust probs
Posted: Thu Jan 28, 2010 9:09 pm
by lamblast
am i right in saying the main bodies on these versions are rubber mounted if so the main body /manifold joint should be flexible ie springs like the sterling ive just turned a sterling into a dj lookalike but its solid mount all the way now including manifold joint you carnt mix the 2 as they will crack especially stainless.i use a mikalor clamp
Re: exhaust probs
Posted: Fri Jan 29, 2010 2:11 pm
by oggy
It is fixed at the shock mount,onto the case(rubber mounted),the clammp i need is for the down pipe to the main part,ps any body got loopys num ??
Re: exhaust probs
Posted: Fri Jan 29, 2010 3:11 pm
by lamblast
as i thought yours is mixed you might not get a loopy clamp the correct size either
