Carb to manifold rubber size
Posted: Wed Jan 27, 2010 5:52 pm
by ArKaTxU
Hi.
What must be the size of a carb to manifodl rubber?
Must the carb touch the manifold, or must be some space between this two things?
Thanks!
Re: Carb to manifold rubber size
Posted: Wed Jan 27, 2010 6:22 pm
by shocky
a push on one should be a tight push fit no gaps
Posted: Wed Jan 27, 2010 10:34 pm
by ArKaTxU
shocky wrote:a push on one should be a tight push fit no gaps
Sorry for my English but i want to say this size, not de diameter:
http://picasaweb.google.com/lh/photo/h6 ... directlink
Thanks!
Posted: Wed Jan 27, 2010 11:41 pm
by rog60
Shouldn't touch, no point to having a remotely mounted carb otherwise :?: :?:
Posted: Thu Jan 28, 2010 12:47 am
by shocky
you can move it in a bit i used a hose like this instead of a normal rubber just cut it to the lenght you want (this type of hose not this actual one )
http://cgi.ebay.co.uk/LAND-ROVER-SERIES ... 414c6814dc
Posted: Thu Jan 28, 2010 12:59 am
by ArKaTxU
OK!
Thank both.
I have two types, the 2normal" one, and the other one like a radiator hose:
http://picasaweb.google.com/lh/photo/6z ... directlink
Posted: Thu Jan 28, 2010 1:56 am
by corrado
The normal type of carb rubber has a raised section inside to stop the carb touching the manifold and also to give a continuous air flow. The radiator type hose doesn't have this but I find it much stronger than normal carb rubbers and much cheaper. If you buy a length of it, say 300 mm, you can cut 4 or 5 pieces for around the same cost as the normal single one.
Posted: Thu Jan 28, 2010 1:53 pm
by ArKaTxU
corrado wrote:The normal type of carb rubber has a raised section inside to stop the carb touching the manifold and also to give a continuous air flow. The radiator type hose doesn't have this but I find it much stronger than normal carb rubbers and much cheaper. If you buy a length of it, say 300 mm, you can cut 4 or 5 pieces for around the same cost as the normal single one.
Fortunately already have one that you sent me ;)
