100/90/10 tyres
Posted: Sun Jan 24, 2010 5:49 pm
Do these effect the gearing much compared to a 350-10? I know they are wider but not sure about the height.Anyone find the handling much better than a 350?
Ta
Ta
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
They do rub a little on the inside of the engine case on mine because I have wide rim on the back, you can buy a spacer washer from MB but I have been informed you can file a little off the inside of the engine case to eleminate this..Its only very faint black mark so its not like your going over the top..I am going to do this with mine.soosh wrote:How much did they rub? Could washers behind the rim eliminate this?
IMO that's a bodge and not good practice. I think to gain sufficient clearance to account for the state of our roads and the impact this would have on tyre shape, the thickness of washers would be prohibitive and offser the rear wheel too much. I also think ScootRS tubeless rims are best avoided too, at least until they own up and do something about their shortcomings, split rims, correct offset valve innertubes and tyre sealant for me at the moment.soosh wrote:How much did they rub? Could washers behind the rim eliminate this?
Done it before and its ok,if use 10mm thick washers,then your in trouble.Been using scoot RS rims for over 4yrs and they have been fine.soulsurfer wrote:IMO that's a bodge and not good practice. I think to gain sufficient clearance to account for the state of our roads and the impact this would have on tyre shape, the thickness of washers would be prohibitive and offser the rear wheel too much. I also think ScootRS tubeless rims are best avoided too, at least until they own up and do something about their shortcomings, split rims, correct offset valve innertubes and tyre sealant for me at the moment.soosh wrote:How much did they rub? Could washers behind the rim eliminate this?
