Page 1 of 2
PM Grimeca Disc
Posted: Thu Jan 21, 2010 11:02 pm
by CPH Lambretta
Anybody got a PM Grimeca disc brake fitted? What do you recon, are they any good?
Also have you got any pictures because I've never seen one of these fitted.
Cheers Nick
Re: PM Grimeca Disc
Posted: Fri Jan 22, 2010 8:44 am
by soulsurfer
Do you mean the Grimeca alloy wheel?
Re: PM Grimeca Disc
Posted: Fri Jan 22, 2010 10:06 am
by frank sanderson
some pics of Grimeca hub fitted to 1st prototype of SCOMADI ,at present you can only have it anti dive as disc is on opposite side to the drum or disc retaing trailing link on a normal susp set up.Anti dive set up is SS and calliper is Grimeca same as ones on all our other hubs its used on PX disc models so no probs with spare pads etc. We have some new links that have been made for us by MB based on his SS disc links that have provision for a normal non anti dive calliper carrier these will be out in next couple of weeks if you dont want anti dive.
The hub is a genuine Grimeca tubeless pressure die cast unit we get them direct from Italy brand new,they are the same width as a std lamby front rim as they have a deep well there are no problems fitting the stronger walled 90+mph tyres like schwalbes.Speedo drive is same thread as italian cable.The hub fits in std forks any link type
They cost around £261.00 incl vat from http://www.pmtuning.co.uk .
we have another version as used on production SCOMADI with a different spoke shape this one is wider about the same as wide lamby rims . this one is only available by special order.
If you go on website http://www.lambrettainnovation.co.uk you can see it fitted on the scoot in SCOMADI sect.
Re: PM Grimeca Disc
Posted: Fri Jan 22, 2010 2:38 pm
by soulsurfer
Hi Frank, Can the calliper and/or carrier plate be easily removed so that the hose can be left fitted when removing the wheel?
CPH Lambretta wrote:Also have you got any pictures because I've never seen one of these fitted.
It would be nice to see one fitted on a finished scooter to see how they look with mudguard etc. ;)
Re: PM Grimeca Disc
Posted: Fri Jan 22, 2010 10:32 pm
by damdam
stolen from another forum :o :mrgreen:
I personally think that this front set up is both good-looking and a good improvement as you have the rim and the hub joined together in one piece, the only downside is that you have a different rim at the rear, so you have to chose which spare wheel put behind the legshields...or carry 2 different type of spare wheels :(
Dam
Re: PM Grimeca Disc
Posted: Fri Jan 22, 2010 10:51 pm
by soulsurfer
damdam wrote:stolen from another forum :o :mrgreen:
Dam
Cheers for that, hope to get some closer pics from said forum ;)
Just carry a repair kit with tubeless, not many m/cycles carry spare wheels :idea:
Re: PM Grimeca Disc
Posted: Fri Jan 22, 2010 11:01 pm
by CPH Lambretta
Hi Damdam,
Thanks for the pictures, I saw these of Scumdogs scoot down under and didn't even notice he had this disc fitted.
I was hopeing for some pictures of one of these discs fitted to a GP in black with normal type dampers and thats exactly what I got! 8-)
Re: PM Grimeca Disc
Posted: Sat Jan 23, 2010 8:42 pm
by damdam
that's right mate, but I like to have a 3th bullet in my gun, is one of the reason why I love classic scooters! :lol:
Re: PM Grimeca Disc
Posted: Tue Feb 02, 2010 1:25 pm
by soulsurfer
Re: PM Grimeca Disc
Posted: Tue Feb 02, 2010 1:48 pm
by Ian Hepworth
damdam wrote:...or carry 2 different type of spare wheels :(
Dam
The front wheel is combined hub/rim, you couldn't carry a spare. (well you could but it would be overkill)
