Page 1 of 2
thought it would be a good idea opinions sought
Posted: Tue Jan 12, 2010 9:49 pm
by davidblythe
thought I would try a pure copper gasket 3mm thick slightly extended to act as a heat sink
on the test one havent extended the sides like I intended too,
but they take more time than I thought they would mainly because I Need to make a better holding tool
also realised they need finishing by hand to suit the exhaust and pipe being used
then realised that I not really sure that it will work
opinions sought
one in picture still to be finished, got too cold in garage
Re: thought it would be a good idea opinions sought
Posted: Tue Jan 12, 2010 9:51 pm
by DJB
Silicone :lol:
Posted: Tue Jan 12, 2010 9:52 pm
by davidblythe
DJB wrote:Silicone :lol:
use silicone myself but was thinking along the heatsink side really
Posted: Tue Jan 12, 2010 9:57 pm
by DJB
I would stick to a normal gasket. If its not broke?
Posted: Tue Jan 12, 2010 10:39 pm
by soullad
David - give it a go, what you got to lose?
Also did you see the thread about using the cylinder cowl as a heat shrink. I.E. using the stud extending connectors / nuts on all 4 head studs and drilling thru 3 new holes in the cylinder cowl.
Posted: Tue Jan 12, 2010 10:43 pm
by davidblythe
soullad wrote:David - give it a go, what you got to lose?
yes I did and am trying out another daft idea along those lines
Posted: Wed Jan 13, 2010 5:57 pm
by mickdale
davidblythe wrote:yes I did and am trying out another daft idea along those lines
if you use the cowling as a heat sink you could weld fins to the cowling underside letting the airflow under the scoot draw heat off?
Posted: Wed Jan 13, 2010 6:17 pm
by cezeta
my mate is using one of these mounted to his exhaust stub. its from a triumph. no idea if it works or not but food for thought.
Posted: Wed Jan 13, 2010 7:07 pm
by rbgaz
please someone tell me what its for/do else i want be able to sleep tonight !!! :shock:
Posted: Wed Jan 13, 2010 7:13 pm
by davidblythe
rbgaz wrote:please someone tell me what its for/do else i want be able to sleep tonight !!! :shock:
have a read of this ebay listing, very common on old brit iron
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
