Bearing Greases
Tosh
SAPPHIRE® 2 TRIPLE LIFE MULTIPURPOSE BEARING GREASE
Long life complex soap thickened NLGI 2 grease with very high resistance to load and good corrosion resistance. Temperature range -30°C to +150°C. SAPPHIRE 2 NLGI No 2 consistency for conventional application.
picked up two tubes of this from my brother just wondered if you think it ok to use for the bearings in the crank department and other places its blue in colour but that won`t make much differance
Tosh
well seeing nobody`s come back with an answer i`m going now with castrol LM around the crank
Diablo
I'll have a look when I go up the workshop but I think I've used this stuff before.
Tosh
thanks diablo its because i`ve 2 tubes i hope with the temps it`s saying it would be ok
soullad
Tosh wrote:well seeing nobody`s come back with an answer i`m going now with castrol LM around the crank
Tosh - just check LM doesn't stand for Low Melting point :D :D
I've always used Castrol BNS for packing out the mag housing etc - are there any better alternatives
Tosh
car shop haddn`t got bns grease but told dad that lm had the same properties and was ok
now stuck were to get some from was planing to re build engine tonight :(
soullad
I just checked - its a high melting point grease ideal for bearings etc and its ideal for you. I didn't mean to hold you up, just thought hang on a minute.......... the LM stands for Lithium - so get that engine built fella. Stick some pics up as you go?
Tosh
soullad wrote:I just checked - its a high melting point grease ideal for bearings etc and its ideal for you. I didn't mean to hold you up, just thought hang on a minute.......... the LM stands for Lithium - so get that engine built fella. Stick some pics up as you go?
thanks soullad for that think i`ll have a guinness tonight in the garage, just av`e to watch were i`m putting it, the grease i mean HIC.HIC :D
i`ll try to put photo up but i`m no bill gates and i allways have trouble nomatter what i do :?
    Users browsing this forum: Semrush [Bot] and 13 guests
