Airbox or not?
Dazza
I'm currently running a Mikuni with shortened manifold, no filter and no hole in panel - and all seems fine.
I was wondering if re-fitting the airbox - baffles removed and connected through to the carb would have positive or negative benefits?
I just thought there may be a better chance of getting more cooler/fresher air from the air scoop than from under the panel?
red ghost
Main scooter: lambretta gp150
You can and alot do, one problem I encountered is that the mikuni sits higher up than a dellorto sh, so the end result is it bunches the bellow(air hose) up and forces the carb down and fouls on the cowling
Maybe a little hard to see,but the bellows isn't sitting in a relaxed fashoin.
So you can cut'n'shut the air box or run something like this;
