Page 1 of 3
dc conversion
Posted: Fri Jan 08, 2010 9:19 pm
by minotaur
successfully entered the world of dc electrics
, thanks for all the help from this forum, i have put an in line fuse on my negative from the battery but what fuse will i need, i have 35w main , normal speedo bulb, led festoon, led rear & will fit 2 pathfinders with 2 x 25w bulb , fuel sender and an egt unit any ideas
Re: dc conversion
Posted: Fri Jan 08, 2010 9:25 pm
by mark
good luck powering all that m8
Re: dc conversion
Posted: Fri Jan 08, 2010 9:33 pm
by minotaur
i do have a 12v 9 amp battery so hoping for the best
Re: dc conversion
Posted: Fri Jan 08, 2010 9:37 pm
by mark
i have been doing this mate and its not as good as you think . the stator (even bgm 120w) does not put out enough amps to charge a battery with nothing more than std lights on
, even then its borderline
. read this post to get more info
http://scooterotica.org/forum/viewtopic.php?f=7&t=7280
no offence meant
Re: dc conversion
Posted: Fri Jan 08, 2010 9:43 pm
by oldbiker
60% higher than the battery nominal rating
ie 5 amphour battery 8A fuse
10 amphour battery 16A fuse
etc etc etc
Re: dc conversion
Posted: Fri Jan 08, 2010 9:46 pm
by minotaur
thanks for the fuse info looks like 15amp for a 9amp battery then, i'll let you know how it all goes thanks guys
Re: dc conversion
Posted: Fri Jan 08, 2010 9:48 pm
by firekdp
A 10A one should be fine.
Re: dc conversion
Posted: Fri Jan 08, 2010 9:59 pm
by minotaur
i'll try 10amp fuse and see how it goes, thanks a lot
Re: dc conversion
Posted: Sat Jan 09, 2010 10:45 am
by minotaur
i am now about to attach my fuel guage and egt unit, i want to splice these to my ignition key switch, it is an aftermarket indian type on a '62 li 125 s3, i want them to work with the battery on my new dc conversion .
ignition works on I, sidelights on II and headlights on III with battery alone and /or engine running so all is well
i need the fuel gauge/egt to work on I, II & III so which colour wire do i connect the lives to, the ignition switch was a non battery type when bought
thanks
Re: dc conversion
Posted: Sat Jan 09, 2010 11:20 am
by byron
as it's an AC switch, sounds like you've already used all the options.
all position l does is disconnect the CDI from earth, nothing else is switched.
but do you need a seperate sidelights and then headlamp positions ?
you could use position ll to switch the power to the gauges.
so [assuming it has colours as per the ones from Scooter Restorations], have the blue from the ignition plugged into a live power, this connects to the black & yellow in position ll, so use these for your gauges.
in position lll brown is conected to orange, so use this to feed your lights, inc to take power to the rear lamp via the [usually] black wire, speedo, festoon and to the main/dip switch.
what handlebar switch have you got ?
then the guages should work in pos ll and continue to work in pos lll when the lights come on too. they won't work [but the engine will run] in pos l
hth
edit: I missed off a "l" earlier
, blue connects to black & yellow in position ll
